🎉Community Raffle - Win $25
Join and Win
Average over attributes
User: "MuehliMan"
New Altair Community Member
Updated by Jocelyn
Hi again,
I have another problem and hope for some help:
My table has values from difference sources. All attributes have the name [value]_[reference]. I would like to average over all attributes belonging to the same [value]. Is this possible using the "Loop over Attributes" Operator or any other way? The References are names (strings) by the way.
Thanks in advance.
Best regards,
Markus
1 - 2 of 21
    User: "haddock"
    Like this ?
    <?xml version="1.0" encoding="UTF-8" standalone="no"?>
    <process version="5.0">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" expanded="true" name="Process">
        <process expanded="true" height="353" width="790">
          <operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"/>
          <operator activated="true" class="generate_aggregation" expanded="true" height="76" name="Generate Aggregation" width="90" x="315" y="30">
            <parameter key="attribute_name" value="plob"/>
            <parameter key="attribute_filter_type" value="regular_expression"/>
            <parameter key="regular_expression" value="att[1-2]"/>
            <parameter key="aggregation_function" value="average"/>
          </operator>
          <connect from_op="Generate Data" from_port="output" to_op="Generate Aggregation" to_port="example set input"/>
          <connect from_op="Generate Aggregation" from_port="example set output" to_port="result 1"/>
        </process>
      </operator>
    </process>
    User: "MuehliMan"
    OP
    Thanks, this worked (as usual). =)
