<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="353" width="790"> <operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"/> <operator activated="true" class="generate_aggregation" expanded="true" height="76" name="Generate Aggregation" width="90" x="315" y="30"> <parameter key="attribute_name" value="plob"/> <parameter key="attribute_filter_type" value="regular_expression"/> <parameter key="regular_expression" value="att[1-2]"/> <parameter key="aggregation_function" value="average"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Generate Aggregation" to_port="example set input"/> <connect from_op="Generate Aggregation" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
