🎉Community Raffle - Win $25
Join and Win
Starting Rapidminer without a GUI from command line
User: "Cleo"
New Altair Community Member
Updated by Jocelyn
Hello,
I have a PS3 (PlayStation 3) with ubuntu 9.10 installed.  When I start rapidminer using "Way 3" (http://rapid-i.com/content/view/17/40/) ie: java -Xmx800m -jar rapidminer.jar it starts.  I can also use java Xmx800m -jar rapidminer /path/fileName.rmp and this works.  In both cases I rapidminer process which takes about 1 hour to run on my normal computer takes about 2 days to run on the ps3.
I think part of the problem my is the PS3 has very little RAM and might run alot faster without the GUI.  I have attempted to start rapidminer 5 without the gui using the example in http://rapid-i.com/rapidforum/index.php/topic,13.msg13.html#msg13 but have been unable to do so.
Thanks in advance,
Cleo
