I have a PS3 (PlayStation 3) with ubuntu 9.10 installed. When I start rapidminer using "Way 3" (
http://rapid-i.com/content/view/17/40/) ie: java -Xmx800m -jar rapidminer.jar it starts. I can also use java Xmx800m -jar rapidminer /path/fileName.rmp and this works. In both cases I rapidminer process which takes about 1 hour to run on my normal computer takes about 2 days to run on the ps3.
I think part of the problem my is the PS3 has very little RAM and might run alot faster without the GUI. I have attempted to start rapidminer 5 without the gui using the example in
http://rapid-i.com/rapidforum/index.php/topic,13.msg13.html#msg13 but have been unable to do so.
Thanks in advance,
Cleo
