Altair RISE
Nominate Yourself Now!
Rename many columns
User: "choose_username"
New Altair Community Member
Updated by Jocelyn
Hi there,
i wanted to rename a column with the Operator Rename. The Problem is that i have to rename 31 columns. As far as i see i do need to use 31 Rename-Operators? My Question is: Is there a way to rename all 31 columns with 1 operator?
thanks in advance
user
1 - 13 of 131
    User: "wessel"
    Use the Loop Attributes operator?
    User: "IngoRM"
    Hi,
    maybe the operators "Rename by Replacing" or "Rename by Generic Names" can also be helpful. If you want to use specific names, looping could indeed be the best option - you could even take the old and new names from another example set...
    Cheers,
    Ingo
    OP
    Hello,
    the approach with the Loop sounds interessting. By trying it i found out that it is neccessary to make use of macros. Is there a tutorial or example how to do this in RM?
    (btw its a great product with great support)
    Greetings
    User
    User: "IngoRM"
    Hi,
    did you try our new Community Extension? Just download and install it from our update- and installation server via the Help menu of RapidMiner. You can search for processes containing the word "Loop" or "Macro" and you will see several examples of processes containing operators making use of them.
    Cheers,
    Ingo
    User: "Andrew2"
    If you want a quick and dirty hack, I successfully used the de-obfuscate operator to rename columns. Provide an obfuscation map file containing a row for each attribute you want to rename in the following form:
    oldname<tab>newname
    The tab is important; spaces cause an error.
    Ugly but effective.
    regards,
    Andrew
    User: "IngoRM"
    Nice one  ;)
    Cheers,
    Ingo
    OP
    thx for the tip. i will give it a try : )
    greetings User
    User: "wessel"
    How to convert all attributes to lower-case?
    OP
    well i simply use the Rename Operator. But maybe there s a solution tryin "Rename by Replacing" in combination with an regular expression like  [A-Z]  ->  [a-z] and a loop or smthing
    greetings
    User
    User: "wessel"
    hmm :P
    Then you need to type 26 replacements..
    User: "IngoRM"
    Hi,
    this is easily possible with a short script. You can find an example process with our Community Extension for RapidMiner. Just download the extension, show the corresponding view and search for the process "Transform Attribute Names to lower Case (Script)". You can then simply download the process and run it directly in your client.
    Cheers,
    Ingo
    User: "wessel"
    oldname<tab>newname
    Ugly but effective.
    regards,
    Andrew
    How does this work?
    User: "Andrew2"
    Here's an example process
    <?xml version="1.0" encoding="UTF-8" standalone="no"?>
    <process version="5.0">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" expanded="true" name="Process">
        <process expanded="true" height="161" width="480">
          <operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data" width="90" x="112" y="75"/>
          <operator activated="true" class="de_obfuscate" expanded="true" height="76" name="rename" width="90" x="380" y="75">
            <parameter key="obfuscation_map_file" value="c:\temp\att.txt"/>
          </operator>
          <connect from_op="Generate Data" from_port="output" to_op="rename" to_port="example set input"/>
          <connect from_op="rename" from_port="example set output" to_port="result 1"/>
        </process>
      </operator>
    </process>
    The file referred to is here
    att1 apple
    att2 banana
    att3 pear
    att4 grape
    att5 orange
    Ugly but effective
    Andrew
