Rename many columns
New Altair Community Member
Updated by Jocelyn
Hi there,
i wanted to rename a column with the Operator Rename. The Problem is that i have to rename 31 columns. As far as i see i do need to use 31 Rename-Operators? My Question is: Is there a way to rename all 31 columns with 1 operator?
thanks in advance
user
thanks in advance
user
1 - 13 of
131
wessel
Use the Loop Attributes operator?
Hi,
did you try our new Community Extension? Just download and install it from our update- and installation server via the Help menu of RapidMiner. You can search for processes containing the word "Loop" or "Macro" and you will see several examples of processes containing operators making use of them.
Cheers,
Ingo
Cheers,
Ingo
If you want a quick and dirty hack, I successfully used the de-obfuscate operator to rename columns. Provide an obfuscation map file containing a row for each attribute you want to rename in the following form:
Ugly but effective.
regards,
Andrew
The tab is important; spaces cause an error.
oldname<tab>newname
Ugly but effective.
regards,
Andrew
Hi,
this is easily possible with a short script. You can find an example process with our Community Extension for RapidMiner. Just download the extension, show the corresponding view and search for the process "Transform Attribute Names to lower Case (Script)". You can then simply download the process and run it directly in your client.
Cheers,
Ingo
Cheers,
Ingo
How does this work?
awchisholm wrote: awchisholm wrote: awchisholm wrote:
If you want a quick and dirty hack, I successfully used the de-obfuscate operator to rename columns. Provide an obfuscation map file containing a row for each attribute you want to rename in the following form:The tab is important; spaces cause an error.
oldname<tab>newname
Ugly but effective.
regards,
Andrew
Here's an example process
The file referred to is here
Andrew
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="5.0">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" expanded="true" name="Process">
<process expanded="true" height="161" width="480">
<operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data" width="90" x="112" y="75"/>
<operator activated="true" class="de_obfuscate" expanded="true" height="76" name="rename" width="90" x="380" y="75">
<parameter key="obfuscation_map_file" value="c:\temp\att.txt"/>
</operator>
<connect from_op="Generate Data" from_port="output" to_op="rename" to_port="example set input"/>
<connect from_op="rename" from_port="example set output" to_port="result 1"/>
</process>
</operator>
</process>
Ugly but effective
att1 apple
att2 banana
att3 pear
att4 grape
att5 orange
Andrew
