"Trouble Installing"
cedavis2
cedavis2 New Altair Community Member
edited November 2024 in Community Q&A
I have tried to install RapidMiner on my Mac OS X but when I try to run the program through rapidminer.jar I get a message that says ...The Java JAR file "rapidminer.jar" could not be launched. Check the Console for possible error messages.  Any ideas of what to do??
Answers
  • land
    land New Altair Community Member
    Hi,
    to start with, I would suggest posting this question in the RapidMiner forum...
    I will move your request, so that someone from there will help you.
    Greetings,
      Sebastian
  • SebastianLoh
    SebastianLoh New Altair Community Member
    Hi cedavis2,
    first of all, sorry for the late request. I hope you've not given up using Rapidminer.
    Which version of Mac Os X are you using?
    Try this:
    - copy the rapidminer.jar on your Desktop
    - open a Terminal (the application is hidden somewhere in the Utilities folder in Applications)
    - then type "cd Desktop" and hit RETURN
    - now type "java -jar rapidminer.jar"
    Normally a double click on the rapidminer.jar is sufficient to start Rapidminer under Mac OS X
    Rapidminer should start right now or give you more information what is going wrong. If it does not work, please post the terminal output.
    I hope I could help,
    Ciao Sebastian Loh.
    P.s. I am using rapidminer under Mac OS 10.6
Welcome!
Welcome!
