Rapidito wrote:Depends on your DM problem... but no, accuracy is never enough. If you are trying to predict a 15%-85% distribution class, your 85% accuracy means absolutely nothing on its own.Try some roc or lift charts... but tell us more about your problem...
Rapidito wrote:What DM book have you got? It seems that especially the newer books consider them...Could you say what is the model about? It should help to define a good evaluation measure.
Rapidito wrote:I can't see it. please upload it in higher resolution.
Rapidito wrote:I say this because I think that in your case the cost of a false 0 is terrible. Am I right?
yogafire wrote:but once again, any false prediction means terrible...
wessel wrote:Or you should calculate the sensitivity at a fixed level of specificity.
