Altair RISE
Nominate Yourself Now!
Text Mining
User: "Chris85"
New Altair Community Member
Updated by Jocelyn
Hello,
I´m writting my Diploma thesis about "structured and unstructured data in Business Intelligence". I need some information about the Text Mining-Plugin! How many languages are supported? Can I export the analyzed text?and who?like a XML? Is there an Text Mining Example?How many formats (pdf xls) are supported?
Thanks
Best regards
Chris
1 - 9 of 91
    User: "IngoRM"
    Hi,
    In principle every language is supported which a) can be represented by characters at all and b) which consists of words which can be detected by some separation character or mechanism. There are, however, some specific operators (preprocessing steps) within the Text Extension which supports a fixed set of languages. For example the step 'stemming' which is supported for German, English, French, Spanish, Portuguese, Italian, Romanian, Dutch, Swedish, Norwegian, Danish, Finnish, Russian, Hungarian, Turkish. But not every process needs stemming and hence there is more often no language restriction at all. That is - in my opinion - one of the major advantages of a statistical approach compared to linguistic approaches.
    Yes. (Dude! Read our marketing materials!  ;) )
    like a XML?
    In almost every format you can think of. With RapidAnalytics also in XSL which can then again be transformed by XSLT. Or you simply use some of the RapidMiner operators like "Write" which also directly support XML. Or you write into a database. Or...
    Again: Read our marketing materials!
    You name the format. I will say 'Yes. This is supported.' In rare cases I would have to answer: 'Huh? Never heard of this one...'  ;D
    Cheers,
    Ingo
    User: "Chris85"
    OP
    thanks
    Can I send you my Text about RapidMinder and you can give me a feedback?
    Thanks
    Best regards
    Chris
    User: "IngoRM"
    Hi again,
    sure. You can send it here if you like or to contact@rapid-i.com
    Cheers,
    Ingo
    User: "andrea11"
    Ingo Mierswa wrote:
    Hi,
    Can I ask you where the language packages? I'm using the Tokenize operator but i don't know where to find the "Italian" tokenizator...
    Thanks!
    User: "colo"
    Hi Andrea,
    there is no language restriction for the existing tokenizer. Ingo referred to the stemmer when naming the supported languages. The tokenizer should work for Italian language. Do you experience problems when trying to tokenize Italian text?
    Regards
    Matthias
    User: "andrea11"
    Hi, thanks for your reply!
    I've not tried it, because i've got to use the Text:Filter Stopwords (English) Operator that is in english... Maybe there's an italian verion of Text:Filter Stopwords?
    Thanks!
    User: "colo"
    Hi,
    having a look at the operators it seems there is no Italian stopword filter. In this case you will probably have to use the "Filter Stopwords (Dictionary)" operator that allows you to define your own stopwords. Maybe there is some public list available somewhere for common Italian stopwords!?
    Regards
    Matthias
    User: "andrea11"
    I was looking for something like it, but i could not find anything...Then, right now i'll test my project with english text and english stopwords filter. When i'll have time, i'll think if is possible to create a list from myself .. Thanks!
    User: "nabilophone11"
    Hi every body
    Please can you tel me how to insert a list of word ( about 600) automaticly in rapidminer 5.1.11, i find just a manual way with " Generate attribut "
    thanks for help
    N
