Apply same preprocessing scheme to trainig set and test set
wessel
wessel New Altair Community Member
edited November 2024 in Community Q&A
Hello,
How to do the same thing twice in RapidMiner?
I have a sequence of preprocessing operators which I need to apply on both my training and test set.
Of course I can copy all these operators, but this often leads to mistakes when you change something and forget to make the same change in the copy.
Regards,
Wessel
Welcome!
Answers
  • SebastianLoh
    SebastianLoh New Altair Community Member
    Hi Wessel,
    I published the solution on the MyExperiment.org portal.
    [Add at 27.5.10]
    Just search for Apply Same Preprocessing to Learning and Validation Data in the community plugin and klick on Open in oprder to load the process.
    Alternatively you can download the process here:
    [end Add]
    Here is the link: http://www.myexperiment.org/workflows/1280
    Ciao Sebastian
  • wessel
    How do I open this xml file?
    Its not text its encrypted.
  • colo
    colo New Altair Community Member
    The download is a bit confusing. Just add .zip to the name of the downloaded file or open it with any zip/extract program and you will find the desired XML-code file inside the archive.
  • SebastianLoh
    Hi Folks,
    i agree, this is confusing. The file should have the .zip ending.
    However, the community plugin provides a search for workflows where you can find all rapidminer processes.
    If you search for Apply Same Preprocessing to Learning and Validation Data you find the process and can just load it by klick on the "Open" button without dealing with downloading and unzipping files.
    Ciao Sebastian.
  • wessel
    I created an account on http://www.myexperiment.org/.
    I added the myexperiment view to RM.
    But It does not let me search.
  • SebastianLoh
    Hi wessel,
    what excactly happens?
    are you behind a proxy?
    You can open the MyExperiment Browser through menu View -> Show View -> MyExperiment Browser
    In the MyExperiment Browser is a serach field where you can enter a term. You can restrict the result to RM porcesses by selecting the checkbox "Show only RM processes"
    Then you should get some results if you press the search button.
    By the way, you actually do not need an acount and/or be logged in to search and open RM processes.
    Ciao Sebastian
  • IngoRM
    IngoRM New Altair Community Member
    Hi,
    Hmm. Usually this should be even possible without having an account as long as the process was published for all. I will try this...
    ...and succeeded. I just opened the view, typed in "Apply Same Preprocessing" into the text field left of the search button and clicked on "Search". The process was found and displayed below. I have selected the process in the list of search results below the search field (containing only this process) and it will be shown on the right. Clicking on open loads the process into RapidMiner.
    I want to write a short description of working with the Community Extension in our blog anyway (containing screenshots etc.) and probably will start during the weekend.
    Cheers,
    Ingo
  • wessel
    Hmm, I'm now trying on my windows pc.
    At least I'm now getting search results, and I can preview work flows.
    But when I click open, the download work flow task never completes.
    Am I behind a proxy? I think not? How do I check? I'm am connected trough a router which is connected to the internet.
    When I login, I never get a confirmation that I'm actually logged in.
    When I type the wrong password, it does not error.
Welcome!
Welcome!
