Setting Binominal Label to positive or negative
The binominal label in my process has the values “up” or “down”. When I use the operator Preformance (Binominal Classification), I have the option select “true positive”, “true negative” etc.
How do I ensure the value “up” is set as “positive”? Sometimes Rapidminer chooses “up” to be positive and other times it is negative.
Cheers,
Cleo
Cheers,
Cleo
