notification e-mail of the execution of the process
andrea_coletta
andrea_coletta New Altair Community Member
edited November 2024 in Community Q&A
Hi. I have a problem about the e-mail notification. Because I have to execute a process which take a lot of time I would be receive an e-mail if the execution takes more than a minute. But RapidMiner can't send the e-mail.
Someone could help me???
Thank you
Welcome!
Answers
  • land
    land New Altair Community Member
    Hi,
    could you please be a little bit more detailed about the error message?
    Greetings,
      Sebastian
  • andrea_coletta
    Here is the error message in log of execution of the process
    Apr 16, 2010 10:24:09 AM SEVERE: Must specify sendmail command to use sendmail.
    I have defined the e-mail address in the options of root process,but RM can't send the e-mail. Why not?
  • land
    Hi,
    you have to got to the preferences, switch to the tab tools and select an appropriate mail protocol for submitting the mail. normally you will make use of smtp, so switch rapidminer.tools.mail.method to smtp and set host, port, user and password for the mail server.
    If you want to use the unix sendmail, just enter a path to the program in rapidminer.tools.mail.sentmail.command.
    Greetings,
      Sebastian
  • andrea_coletta
    I have setted the e-mail parameter in the tab Preferences for e-mail notification, but RapidMiner launch this exception
    Apr 19, 2010 2:58:47 PM SEVERE: Cannot send mail to graziocoletta@virgilio.it: javax.mail.MessagingException: Could not connect to SMTP host: out.virgilio.it, port: 25;
      nested exception is:
    java.net.ConnectException: Connection timed out: connect
    So i can't receive e-mail notification.
    Someone coud help me?
  • fischer
    fischer New Altair Community Member
    Hi,
    could that be a firewall problem?
    Cheers,
    Simon
  • andrea_coletta
    no, it couldn't. The firewall is Ok. I don't know why I can't an e-mail notification. Could you help me?
    Thank you
  • fischer
    Can you contact the given host and port outside RM?
    Cheers,
    Simon
Welcome!
Welcome!
