Problems when copying XML
Hi,
When I am copying the XML from the forum ,the process window is not displaying operator diagrams in RM5.
For example.
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="5.0">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" expanded="true" name="Root">
<description>Using a logistic regression learner for a classification task of numerical data.</description>
<process expanded="true" height="584" width="962">
<operator activated="true" class="retrieve" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30">
<parameter key="repository_entry" value="../../data/Sonar"/>
</operator>
<operator activated="true" class="logistic_regression" expanded="true" height="94" name="MyKLRLearner" width="90" x="179" y="30">
<parameter key="calculate_weights" value="false"/>
<parameter key="return_optimization_performance" value="false"/>
</operator>
<operator activated="true" class="apply_model" expanded="true" height="76" name="Apply Model" width="90" x="431" y="28">
</operator>
<connect from_op="Retrieve" from_port="output" to_op="MyKLRLearner" to_port="training set"/>
<connect from_op="MyKLRLearner" from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_op="MyKLRLearner" from_port="exampleSet" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Apply Model" from_port="labelled data" to_port="result 2"/>
<connect from_op="Apply Model" from_port="model" to_port="result 1"/>
<portSpacing port="sink_result 3" spacing="0"/>
</process>
</operator>
</process>
Thanks
Ratheesan
For example.
<context>
<input/>
<output/>
<macros/>
</context>
</operator>
</operator>
</operator>
</process>
</operator>
</process>
Thanks
Ratheesan
After inserting the process, click on the fat green ok-button in the upper left corner of the tab.
