🎉Community Raffle - Win $25
Join and Win
"Rapid miner in R"
User: "m_r_nour"
New Altair Community Member
Updated by Jocelyn
Hi
RWeka packag in allow us to implement weka algorithms in R.
I'm wondering  any way to use Rapidminer in .
Thanks
REZA
1 - 4 of 41
    User: "steffen"
    Plain and simple: Currently there is no solution for this problem.
    You could try to create such a package using rJava/JRI, but frankly, I do not see any advantage of this approach ... embedding R into rapidminer => yes, but the other way ...
    regards,
    steffen
    User: "wessel"
    Are you sure?
    There is run rapidminer on a remote server support, as far as I know.
    Should be able to run rapidminer from the command line. (Call cmd in R)
    And load the results file into R.
    User: "steffen"
    well ... using the detour via the os is nearly always an option.
    I simply skipped this option (in my mind) because I thought reza was looking for something similar to the RWeka-package. But of course you are correct.
    regards,
    steffen
    User: "wessel"
    Ah, like that, yes in that case it's a no.
    Wouldn't make much sense to embed Rapid-miner as a package in R.
    R is already really slow, and this would probably become mega slow.
