"Rapid miner in R"
m_r_nour
m_r_nour New Altair Community Member
edited November 2024 in Community Q&A
Hi
RWeka packag in allow us to implement weka algorithms in R.
I'm wondering  any way to use Rapidminer in .
Thanks
REZA
Welcome!
Answers
  • steffen
    steffen New Altair Community Member
    Plain and simple: Currently there is no solution for this problem.
    You could try to create such a package using rJava/JRI, but frankly, I do not see any advantage of this approach ... embedding R into rapidminer => yes, but the other way ...
    regards,
    steffen
  • wessel
    wessel New Altair Community Member
    Are you sure?
    There is run rapidminer on a remote server support, as far as I know.
    Should be able to run rapidminer from the command line. (Call cmd in R)
    And load the results file into R.
  • steffen
    well ... using the detour via the os is nearly always an option.
    I simply skipped this option (in my mind) because I thought reza was looking for something similar to the RWeka-package. But of course you are correct.
    regards,
    steffen
  • wessel
    Ah, like that, yes in that case it's a no.
    Wouldn't make much sense to embed Rapid-miner as a package in R.
    R is already really slow, and this would probably become mega slow.
Welcome!
Welcome!
