Problem with the naives bayes learner
Hello i am having some problems with the Naives Bayes learner, it looks like when you add a X-Validation and set the parameters to full estimation mode with a fix kernel setting, the learner start doing non-predictions for most of the rows. I think it could be a bug, can anybody help me please.
This is my model:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="5.0">
<context>
<input>
<location/>
</input>
<output>
<location/>
<location/>
</output>
<macros/>
</context>
<operator activated="true" class="process" expanded="true" name="Root">
<process expanded="true" height="444" width="435">
<operator activated="true" class="retrieve" expanded="true" height="60" name="Retrieve (2)" width="90" x="45" y="30">
<parameter key="repository_entry" value="adult"/>
</operator>
<operator activated="true" class="sample" expanded="true" height="76" name="Sample" width="90" x="179" y="30">
<parameter key="sample_size" value="3500"/>
<parameter key="use_local_random_seed" value="true"/>
</operator>
<operator activated="true" class="x_validation" expanded="true" height="112" name="Validation" width="90" x="315" y="30">
<process expanded="true" height="444" width="200">
<operator activated="true" class="naive_bayes_kernel" expanded="true" height="76" name="Naive Bayes (Kernel)" width="90" x="38" y="61">
<parameter key="estimation_mode" value="full"/>
<parameter key="bandwidth_selection" value="fix"/>
</operator>
<connect from_port="training" to_op="Naive Bayes (Kernel)" to_port="training set"/>
<connect from_op="Naive Bayes (Kernel)" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
<portSpacing port="sink_model" spacing="0"/>
<portSpacing port="sink_through 1" spacing="0"/>
</process>
<operator activated="true" class="apply_model" expanded="true" height="76" name="Apply Model" width="90" x="45" y="120">
</operator>
<operator activated="true" class="performance" expanded="true" height="76" name="Performance" width="90" x="92" y="251"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="source_model" spacing="18"/>
<portSpacing port="source_test set" spacing="18"/>
<portSpacing port="source_through 1" spacing="0"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
</operator>
<connect from_op="Retrieve (2)" from_port="output" to_op="Sample" to_port="example set input"/>
<connect from_op="Sample" from_port="example set output" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="averagable 1" to_port="result 1"/>
</process>
</operator>
</process>
And the data is extracted from this website: http://archive.ics.uci.edu/ml/datasets/Census+Income
Thanks.
This is my model:
<context>
<input>
<location/>
</input>
<output>
<location/>
<location/>
</output>
<macros/>
</context>
</operator>
</operator>
</operator>
</process>
</operator>
</process>
</operator>
</process>
</operator>
</process>
Thanks.
1 - 1 of
11
yes there's an problem inside. We will resolve it as soon as possible.
Greetings,
Sebastian
