🎉Community Raffle - Win $25
Join and Win
"Obtaining gain metrics from a decision tree model"
User: "winds"
New Altair Community Member
Updated by Jocelyn
Hi --
Once I've run a DecisionTree learner, is there a way to obtain the attribute selection metric that was computed at each node (e.g. information gain or gain ratio)?
I'm using ModelWriter to output the results, but I don't see that information there.
Also, is there an option to obtain other information such as fraction of data that was split at each node?
Any help much appreciated.
Thanks!
1 - 2 of 21
    User: "steffen"
    Hello winds
    I am sure (at least with 99%) that is is not possible without digging into the code and alteration of the decision-tree-builder. Beside: It makes no sense that the requested information is stored in the model itself since it is not needed for application.
    greetings,
    steffen
    User: "land"
    Hi Wind,
    Steffen is right. This isn't saved in the model at all. Of course one could change it to be saved.
    Greetings,
      Sebastian
