1 - 7 of
71
Hi, thank you for answering.
I've installed 5.0.003 and now it's reporting another error. It says "numerical attributes not supported". I've used "Generate Up-selling Data" as automatic data generator and the problem persists. I've logged the process with logverbosity = "all". The results are here:
Thank you very much
Mar 4, 2010 11:58:06 AM com.rapidminer.Process prepareRun
FINE: Initialising process setup.
Mar 4, 2010 11:58:06 AM com.rapidminer.tools.WrapperLoggingHandler log
INFO: No filename given for result file, using stdout for logging results!
FINE: Process initialised.
Mar 4, 2010 11:58:06 AM com.rapidminer.Process loadInitialData
INFO: Loading initial data.
FINE: Input #1 not specified.
Mar 4, 2010 11:58:06 AM com.rapidminer.Process run
INFO: Process starts
FINE: Process:
Process[1] (Process)
subprocess 'Main Process'
+- Generate Up-Selling Data[1] (Generate Up-Selling Data)
+- CHAID[1] (CHAID)
Mar 4, 2010 11:58:06 AM com.rapidminer.operator.Operator execute
FINE: Starting application 1 of operator Process
FINER: Process called 1st time with input:
Mar 4, 2010 11:58:06 AM com.rapidminer.operator.execution.SimpleUnitExecutor execute
FINE: Executing subprocess Process.Main Process. Execution order is: [Generate Up-Selling Data (Generate Up-Selling Data), CHAID (CHAID)]
FINE: Starting application 1 of operator Generate Up-Selling Data
FINER: Generate Up-Selling Data called 1st time with input:
FINE: Completed application 1 of operator Generate Up-Selling Data
FINER: Generate Up-Selling Data returned with output:
outputSimpleExampleSet:
100 examples,
8 regular attributes,
special attributes = {
label = #8: label (nominal/single_value)/values=[product_1, product_2, product_3]
FINEST: Generate Up-Selling Data: execution time was 2 ms
FINE: Starting application 1 of operator CHAID
FINER: CHAID called 1st time with input:
training setSimpleExampleSet:
100 examples,
Mar 4, 2010 11:58:06 AM com.rapidminer.operator.learner.tree.CHAIDLearner$1 getNominalBenefit
INFO: Calc benefit for: SimpleExampleSet:
100 examples,
1 regular attributes,
INFO: Weights are: AttributeWeights (containing weights for 1 attributes)
INFO: W(name)=1.0
OK. Other implementations of CHAID does.
Sebastian Land wrote:
Hi,
I think you misunderstood my solution: Chaid simply does not support numerical attributes, so I removed the erroneous entry that it does! The description of it's behavior was changed, not the behavior itself.
Greetings,
Sebastian
Thank you
which version of RapidMiner are you using? In the most current version I cannot reproduce this problem easily.
If you are using version 5.0.003, please build a process where you use only data generators and that still reproduces the problem. If you could post it here, I would be able to find the bug if it still exists.
Greetings,
Sebastian
