Mar 4, 2010 11:58:06 AM com.rapidminer.Process prepareRunFINE: Initialising process setup.Mar 4, 2010 11:58:06 AM com.rapidminer.tools.WrapperLoggingHandler logINFO: No filename given for result file, using stdout for logging results!Mar 4, 2010 11:58:06 AM com.rapidminer.Process prepareRunFINE: Process initialised.Mar 4, 2010 11:58:06 AM com.rapidminer.Process loadInitialDataINFO: Loading initial data.Mar 4, 2010 11:58:06 AM com.rapidminer.Process loadInitialDataFINE: Input #1 not specified.Mar 4, 2010 11:58:06 AM com.rapidminer.Process runINFO: Process startsMar 4, 2010 11:58:06 AM com.rapidminer.Process runFINE: Process: Process[1] (Process) subprocess 'Main Process' +- Generate Up-Selling Data[1] (Generate Up-Selling Data) +- CHAID[1] (CHAID)Mar 4, 2010 11:58:06 AM com.rapidminer.operator.Operator executeFINE: Starting application 1 of operator ProcessMar 4, 2010 11:58:06 AM com.rapidminer.operator.Operator executeFINER: Process called 1st time with input:Mar 4, 2010 11:58:06 AM com.rapidminer.operator.execution.SimpleUnitExecutor executeFINE: Executing subprocess Process.Main Process. Execution order is: [Generate Up-Selling Data (Generate Up-Selling Data), CHAID (CHAID)]Mar 4, 2010 11:58:06 AM com.rapidminer.operator.Operator executeFINE: Starting application 1 of operator Generate Up-Selling DataMar 4, 2010 11:58:06 AM com.rapidminer.operator.Operator executeFINER: Generate Up-Selling Data called 1st time with input:Mar 4, 2010 11:58:06 AM com.rapidminer.operator.Operator executeFINE: Completed application 1 of operator Generate Up-Selling DataMar 4, 2010 11:58:06 AM com.rapidminer.operator.Operator executeFINER: Generate Up-Selling Data returned with output: outputSimpleExampleSet:100 examples,8 regular attributes,special attributes = { label = #8: label (nominal/single_value)/values=[product_1, product_2, product_3]}Mar 4, 2010 11:58:06 AM com.rapidminer.operator.Operator executeFINEST: Generate Up-Selling Data: execution time was 2 msMar 4, 2010 11:58:06 AM com.rapidminer.operator.Operator executeFINE: Starting application 1 of operator CHAIDMar 4, 2010 11:58:06 AM com.rapidminer.operator.Operator executeFINER: CHAID called 1st time with input: training setSimpleExampleSet:100 examples,8 regular attributes,special attributes = { label = #8: label (nominal/single_value)/values=[product_1, product_2, product_3]}Mar 4, 2010 11:58:06 AM com.rapidminer.operator.learner.tree.CHAIDLearner$1 getNominalBenefitINFO: Calc benefit for: SimpleExampleSet:100 examples,1 regular attributes,special attributes = { label = #8: label (nominal/single_value)/values=[product_1, product_2, product_3]}Mar 4, 2010 11:58:06 AM com.rapidminer.operator.learner.tree.CHAIDLearner$1 getNominalBenefitINFO: Weights are: AttributeWeights (containing weights for 1 attributes)Mar 4, 2010 11:58:06 AM com.rapidminer.operator.learner.tree.CHAIDLearner$1 getNominalBenefitINFO: W(name)=1.0
Sebastian Land wrote:Hi,I think you misunderstood my solution: Chaid simply does not support numerical attributes, so I removed the erroneous entry that it does! The description of it's behavior was changed, not the behavior itself.Greetings, Sebastian
