RapidMiner Update: 5001 --> 5-3 works, but doesn't
Just seeing if others had this problem. Rapidminer says that there is a new version. when I go to install the new version using the component updating tool, the update appears to happen, but when I go back to the same tool, it indicates that my installed version is still 5.0.0001.
I have tried this on my 32 and 64 bit machines, running everything as an administrator.
... is this a bug?
... is this a bug?
