🎉Community Raffle - Win $25
Join and Win
Relating datasets
artdijkUser: "artdijk"
New Altair Community Member
Updated by Jocelyn
I am new to datamining and RM,
I want to relate two data tables. Each table has a unique key of date and number. Thus the tables should be related via this key. How can this be done in RM ?
Thanks
Arthur
1 - 4 of 41
    landUser: "land"
    Hi Arthur,
    what exactly do you mean by relate? I guess it's the same you do, when you join some relational data base tables? We have an operator called "Join" which will do this.
    Greetings,
      Sebastian
    OP
    Thanks Sebastian,
    The problem is before the join is executed.
    Table A: has as field names: Flight Date Delay Pax
    Table B:  has as field names: Flight Date Report
    In the result of the Join I want to have a table C which has as rows the flights that appears in both tables and as fieldnames the fieldnames that appear in both tables. So I can see how many pax had delay.
    Table A and Table B have no Id. They are linked by Flight and Date.
    How is this done in Rapid Miner,
    Thanks
    Arthur
    landUser: "land"
    Hi Arthur,
    so neither flight and date are unique, but flight + date is unique? Then I would suggest building a new id column from the values of flight and date column. This column can be used for the join. Let make a short sample process:
    After we generated some data and transformed it for having an comparable situation, we build a new id like attribute by concatenating the values of this two attribute:
    <?xml version="1.0" encoding="UTF-8" standalone="no"?>
    <process version="5.0">
      <context>
        <input>
          <location/>
        </input>
        <output>
          <location/>
          <location/>
        </output>
        <macros/>
      </context>
      <operator activated="true" class="process" expanded="true" name="Process">
        <process expanded="true" height="296" width="1018">
          <operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30">
            <parameter key="number_examples" value="150"/>
            <parameter key="use_local_random_seed" value="true"/>
          </operator>
          <operator activated="true" class="rename" expanded="true" height="76" name="Rename" width="90" x="179" y="30">
            <parameter key="old_name" value="att1"/>
            <parameter key="new_name" value="Flight"/>
          </operator>
          <operator activated="true" class="rename" expanded="true" height="76" name="Rename (2)" width="90" x="313" y="30">
            <parameter key="old_name" value="att2"/>
            <parameter key="new_name" value="Date"/>
          </operator>
          <operator activated="true" class="numerical_to_polynominal" expanded="true" height="76" name="Numerical to Polynominal" width="90" x="447" y="30"/>
          <operator activated="true" class="generate_attributes" expanded="true" height="76" name="Generate Attributes" width="90" x="581" y="30">
            <list key="function_descriptions">
              <parameter key="FlightDate" value="Flight + &quot; - &quot; + Date"/>
            </list>
          </operator>
          <operator activated="true" class="set_role" expanded="true" height="76" name="Set Role" width="90" x="715" y="30">
            <parameter key="name" value="FlightDate"/>
            <parameter key="target_role" value="id"/>
          </operator>
          <operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data (2)" width="90" x="45" y="210">
          </operator>
          <operator activated="true" class="rename" expanded="true" height="76" name="Rename (3)" width="90" x="175" y="210">
          </operator>
          <operator activated="true" class="rename" expanded="true" height="76" name="Rename (4)" width="90" x="310" y="210">
          </operator>
          <operator activated="true" class="numerical_to_polynominal" expanded="true" height="76" name="Numerical to Polynominal (2)" width="90" x="445" y="210"/>
          <operator activated="true" class="generate_attributes" expanded="true" height="76" name="Generate Attributes (2)" width="90" x="580" y="210">
            </list>
          </operator>
          <operator activated="true" class="set_role" expanded="true" height="76" name="Set Role (2)" width="90" x="715" y="210">
          </operator>
          <operator activated="true" class="join" expanded="true" height="76" name="Join" width="90" x="916" y="75"/>
          <connect from_op="Generate Data" from_port="output" to_op="Rename" to_port="example set input"/>
          <connect from_op="Rename" from_port="example set output" to_op="Rename (2)" to_port="example set input"/>
          <connect from_op="Rename (2)" from_port="example set output" to_op="Numerical to Polynominal" to_port="example set input"/>
          <connect from_op="Numerical to Polynominal" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/>
          <connect from_op="Generate Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/>
          <connect from_op="Set Role" from_port="example set output" to_op="Join" to_port="left"/>
          <connect from_op="Generate Data (2)" from_port="output" to_op="Rename (3)" to_port="example set input"/>
          <connect from_op="Rename (3)" from_port="example set output" to_op="Rename (4)" to_port="example set input"/>
          <connect from_op="Rename (4)" from_port="example set output" to_op="Numerical to Polynominal (2)" to_port="example set input"/>
          <connect from_op="Numerical to Polynominal (2)" from_port="example set output" to_op="Generate Attributes (2)" to_port="example set input"/>
          <connect from_op="Generate Attributes (2)" from_port="example set output" to_op="Set Role (2)" to_port="example set input"/>
          <connect from_op="Set Role (2)" from_port="example set output" to_op="Join" to_port="right"/>
          <connect from_op="Join" from_port="join" to_port="result 1"/>
        </process>
      </operator>
    </process>
    I hope, it will help you.
    Greetings,
      Sebastian
    OP
    Thanks for your process. It is not yet the solution but we are getting closer.
    I can never get the same Id in both file for the same FlightNr and Data combination because the number of records is different in both files.
    I try to explain the problem in different words:
    File A has fields: FlightNr, Date, Pax, Fuel
    File B has fields: FlightNr, Date, Event
    File B has less records. Only the flight that have an event are in file B.
    I want to get
    File C with fields: FlightNr, Date, Pax, Fuel, Event
    On most flights no events are recorded so many event fields will be empty in file C.
    Resulting file example:
    Flt112,1-1-2010,34,2300,?
    Flt116,1-1,2010,45,2900,turbulence
    Flt112,2-1-2010,23,2100,?
    Flt116,2-1-2010,41,2800,?
    Thanks
    Arthur
