1 - 6 of
61
I didn't think so....I cant get anything from the output to show up visually. Are you thinking to export the model and look at XML? Something like this: is that the best way? Start with a really small model I know the answer to and then try and find the right nodes in the XML?
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="5.0">
<context>
<input>
<location/>
</input>
<output>
<location/>
<location/>
</output>
<macros/>
</context>
<operator activated="true" class="process" expanded="true" name="Process">
<process expanded="true" height="100" width="145">
<operator activated="true" class="generate_massive_data" expanded="true" height="60" name="Generate Massive Data" width="90" x="45" y="30">
<parameter key="number_examples" value="1000"/>
<parameter key="number_attributes" value="10"/>
</operator>
<operator activated="true" class="singular_value_decomposition" expanded="true" height="94" name="SVD" width="90" x="219" y="69">
<parameter key="return_preprocessing_model" value="true"/>
</operator>
<operator activated="true" class="write_model" expanded="true" height="60" name="Write Model" width="90" x="390" y="161">
<parameter key="model_file" value="C:\Documents and Settings\Owner\Desktop\out.mod"/>
<parameter key="output_type" value="XML"/>
</operator>
<connect from_op="Generate Massive Data" from_port="output" to_op="SVD" to_port="example set input"/>
<connect from_op="SVD" from_port="preprocessing model" to_op="Write Model" to_port="input"/>
<connect from_op="Write Model" from_port="through" to_port="result 1"/>
</process>
</operator>
</process>
Hi,
as I saw now, all this information is discarded in RapidMiner and hence currently cannot be shown in the visualization of the preprocessing model. If you take a look at the result of the PCA, it's in deed possible to use these values for displaying. I could add that relative easily I guess, but this and next week, there won't be the time for it. I'm very busy with customer projects, that bye the way are about text mining. So I'm curious about the runtime of SVD with many features and the amount of memory it needs. As far as I can see, it needs the complete matrix, so it will crash with my around 40.000 word attributes. Did you made any experience with that? What about the classification performance, is it worth implementing a special SVD for sparse matrices?
Greetings,
Sebastian
Greetings,
Sebastian
Hi, Sebastian.
regarding your question: "is it worth implementing a special SVD for sparse matrices?"
I think absolutely YES. it worth for sure. A couple of days ago I tested the SVD operator on my text dataset with 23000 features on a relatively high performance machine. After 10 hours the algorithm was finished!!!
As far as I know, LSA algorithm has tackled with this problem. It just use an approximation of term-document matrix (which is so smaller than the original matrix). So, I kindly suggest that RM team try to embed an LSA operator in RM.
cheers.
cheers.
as usual you cannot say how things will work before you tested it. One mostly applies the X-Validation to get a performance estimation if it's a classification or regression task. Clusterings might be evaluated using cluster measures. You might optimize the number of dimensions by iterating over this parameter and test every combination. There are operators for this, all starting with Optimize Parameters.
But anyway, I doubt that the SVD will work very well on Text Datasets, simply because it might take much to long time to compute the Singular Value Decomposition of such a huge matrix, as they frequently occur in text mining.
Greetings,
Sebastian
