1 - 2 of
21
Hi,
you could use the Reporting Extension to write arbitrary results into automatically generated reports. If you choose the HTML output, you might export the images as SVG, which will then be written into a directory. Although it's not directly possible to export a single tree as image, this way an file with the image could be retrieved. You might delete the remaining files.
Greetings,
Sebastian
Greetings,
Sebastian
-Gagi
