"Getting started - very simple neural network training
Harumpel
Harumpel New Altair Community Member
edited November 2024 in Community Q&A
Hi there,
I am working on the business intelligence part of a large project and looking for an appropriate tool. RapidMiner looks very promising so far though I have trouble to get a simple neural net training running. As a an initial point for experimenting, I'd like RapidMiner to learn the body mass index formula classification.
I've got two files, "training" and "testing", each containing 100 data examples. They both look like that
69 189 38 0
66 193 60 -1
63 161 59 1
74 187 36 1
68 182 37 0
63 169 46 1
75 158 30 -1
92 145 47 -1
52 160 50 0
The format is: weight (kg) - height (cm) - age (y) - classification (1 = superb, 0 = ok, -1 = bad), e.g. the first line means a person weighs 69 kilo, is 189cm tall at the age of 38 which is "ok".
Now I can import the file "training" and connect it to a neural net. The neural net I connect with the output. RapidMiner trains the net and delivers the weights.
Now how do I test the weights with the test set? Help would be very much appreciated.
Kind Regards
Theo
Welcome!
Answers
  • land
    land New Altair Community Member
    Hi Theo,
    that's exactly what's RapidMiner was originally designed for. I will post a (senseless) example process which will make it instantly clear, how to use a test set for performance evaluation:
    <?xml version="1.0" encoding="UTF-8" standalone="no"?>
    <process version="5.0">
      <context>
        <input>
          <location/>
        </input>
        <output>
          <location/>
          <location/>
          <location/>
        </output>
        <macros/>
      </context>
      <operator activated="true" class="process" expanded="true" name="Process">
        <process expanded="true" height="206" width="614">
          <operator activated="true" class="generate_data" expanded="true" height="60" name="Train Data" width="90" x="45" y="30">
            <parameter key="target_function" value="random classification"/>
          </operator>
          <operator activated="true" class="neural_net" expanded="true" height="76" name="Neural Net" width="90" x="246" y="30">
            <list key="hidden_layers"/>
          </operator>
          <operator activated="true" class="generate_data" expanded="true" height="60" name="Test Data" width="90" x="246" y="120">
          </operator>
          <operator activated="true" class="apply_model" expanded="true" height="76" name="Apply Model" width="90" x="380" y="30">
          </operator>
          <operator activated="true" class="performance_classification" expanded="true" height="76" name="Performance" width="90" x="514" y="30">
            <parameter key="accuracy" value="true"/>
            <list key="class_weights"/>
          </operator>
          <connect from_op="Train Data" from_port="output" to_op="Neural Net" to_port="training set"/>
          <connect from_op="Neural Net" from_port="model" to_op="Apply Model" to_port="model"/>
          <connect from_op="Test Data" from_port="output" to_op="Apply Model" to_port="unlabelled data"/>
          <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/>
          <connect from_op="Performance" from_port="performance" to_port="result 1"/>
          <connect from_op="Performance" from_port="example set" to_port="result 2"/>
          <portSpacing port="sink_result 3" spacing="0"/>
        </process>
      </operator>
    </process>
    It's a RapidMiner 5 process and I would recommend to switch to RapidMiner 5, if you are still using RapidMiner 4.x.
    For getting an impression of what can be done with RapidMiner, I would recommend to go through the samples delivered with RapidMiner. Many important design patterns and most important operators are described there, together with sample processes.
    Greetings,
      Sebastian
  • Harumpel
    Hi Sebastian,
    thank you for the help, your example was very much the same scheme I had used. Except, of course, for the data import, which seems to make the most difficulties for me now. Could you maybe take a look at my process:
      <context>
        <input>
          <location/>
        </input>
        <output>
          <location/>
          <location/>
          <location/>
          <location/>
        </output>
        <macros/>
      </context>
        <process expanded="true" height="597" width="904">
          <operator activated="true" class="read_aml" expanded="true" height="60" name="Read AML" width="90" x="36" y="81">
            <parameter key="attributes" value="C:\testNN4\trainingaml.aml"/>
          </operator>
          <operator activated="true" class="neural_net" expanded="true" height="76" name="Neural Net" width="90" x="179" y="30">
            <list key="hidden_layers">
              <parameter key="null" value="7"/>
              <parameter key="null" value="3"/>
            </list>
            <parameter key="training_cycles" value="50"/>
            <parameter key="decay" value="true"/>
          </operator>
          <operator activated="true" class="read_aml" expanded="true" height="60" name="Read AML (2)" width="90" x="45" y="210">
            <parameter key="attributes" value="C:\testNN4\testaml.aml"/>
          </operator>
          <operator activated="true" class="apply_model" expanded="true" height="76" name="Apply Model" width="90" x="313" y="165">
          </operator>
          <operator activated="true" class="multiply" expanded="true" height="94" name="Multiply" width="90" x="447" y="120"/>
          <operator activated="true" class="performance" expanded="true" height="76" name="Performance" width="90" x="648" y="210"/>
          <connect from_op="Read AML" from_port="output" to_op="Neural Net" to_port="training set"/>
          <connect from_op="Neural Net" from_port="exampleSet" to_port="result 2"/>
          <connect from_op="Read AML (2)" from_port="output" to_op="Apply Model" to_port="unlabelled data"/>
          <connect from_op="Apply Model" from_port="labelled data" to_op="Multiply" to_port="input"/>
          <connect from_op="Multiply" from_port="output 1" to_op="Performance" to_port="labelled data"/>
          <connect from_op="Multiply" from_port="output 2" to_port="result 3"/>
          <portSpacing port="sink_result 4" spacing="0"/>
        </process>
      </operator>
    </process>
    It does learn now, but is still faulty, since the learning capability of the neural net seems to heaviliy vary with the amount of testing (!!) data.
    Kind Regards
    Theo
  • land
    Hi Theo,
    the Capabilities are not dependent on the amount of data, but of the type of data. I would suggest using the Repository for having a correct MetaData Transformation.
    Without further information about what's going wrong, I cannot say, why it does.
    Greetings,
      Sebastian
  • Harumpel
    Hi,
    I finally succeeded in building a process that learns the body mass index formula. The model learned by the neural net classifies softly between +1 (healthy) and -1 (overweight). Value are e.g. "+1.037" or "-0.360".
    I would like the values to be "crisp", e.g. separated in 3 classes "+1", "zero" and "-1" which symbolize the health of the patient. How do I do that?
    I already tried mapping and threshold but it didnt work out. The "map" operator would not touch the "prediction (BMI)" column which is produced by the "apply model" operator. How do I employ a correct mapping?
    Thanks in advance
    Theo
  • land
    Hi Theo,
    I would recommend using the discretize by user specification operator. You will have to enter the upper bound for each class and would have to select the prediction column as single attribute setting the attribute filter type to single attribute and then selecting the attribute.
    Greetings,
      Sebastian
  • Harumpel
    Hello Sebastian,
    thank you very much, "discretize" is exactly what was needed  :)  Though I still do not understand why it is not possible to use "map" or "threshold".
    Is there an easy and intuitive way to modify existing modules? Or combine existing modules to new ones?
    Kind Regards
    Theo
  • land
    Hi,
    the map operator is meant for nominal attributes, where you map one nominal value to another. The threshold operators are used for applying on classification confidences to bias the classification result manually.
    What do you mean by modules?
    Greetings,
      Sebastian
  • Harumpel
    Good Morning,
    I see. Sounds like it was also the right operator for the task I finally solved by "discretize".
    Sorry, I meant "operators".
    Kind Regards
    Theo
  • land
    Hi Theo,
    operators are fixed units inside RapidMiner. You might relative easily extend RapidMiner with your own operators solving your own problems by writing an Extension. This is done in Java and you might inherit from the existing operators there to change some of their behavior. A whitepaper for developers is on the way. (See the other many threads about this...)
    Greetings,
      Sebastian
Welcome!
Welcome!
