Altair RISE
Nominate Yourself Now!
Result writer into excel
User: "sudheendra"
New Altair Community Member
Updated by Jocelyn
Hai,
How can I write my result into an excel sheet. My intention is to save the aggregate functions(SD,AVG etc) and to take it again into RM  for further analysis. I am using the following process
DatabaseExampleSource[1] (DatabaseExampleSource)
  +- Nominal2Numerical[0] (Nominal2Numerical)
  +- Aggregation[1] (Aggregation)
  +- ResultWriter[1] (ResultWriter).
Here I am getting the result as .res file, but not getting in excel format after saving it with .xls format.
Thanks,
Sekhar
1 - 1 of 11
    User: "land"
    Hi,
    if you are going to write an ExampleSet, you should take a look at the ExampleSetWriter, not the generic ResultWriter. There's an operator called ExcelExampleSetWriter, which does want the name already says: Writing an example set into an excel file.
    Greetings,
      Sebastian
