Table_LD_LQ_Light_OnePosition.PFM
Ali Sawan
Ali Sawan Altair Community Member
edited November 2022 in Community Q&A
I have a reluctance motor on flux 2d and i am trying to find the table from Ld and Lq . I found out that it should be in 3d and i have to run the INIT_AFIR first but the problem it is only defined when i have magnets but in the reluctance motor there isnt any magnets .
can you please help me with finding my way through ?
Ali
Best Answer
  • C_Favre
    C_Favre
    Altair Employee
    edited November 2022 Answer ✓
    Hi,
    The macro Table_LD_LQ_Light_OnePosition.PFM has been developped specifically for Axial Flux Machine, so for 3D project. If I correctly understood you project is 2D ? In this case the macro to use should be CreateLookUpTableFromTMProjectDQLight.PFM developped for 2D project and more especially for PM motor. I have checked the code and for me the macro should work in case of reluctance motor (without magnet)
    I hope this helps.
    Best regards.
    Cyril Favre
Answers
  • C_Favre
    C_Favre
    Altair Employee
    Hi,
    I hope this helps.
    Best regards.
    Cyril Favre
  • Ali Sawan
    Hi,
    I hope this helps.
    Best regards.
    Cyril Favre
    Thank you Cyril , I have used that Macro and it worked but the output was an .oml file . How do you think the right way to open it ?
    I installed Altair compose but it looks like i should learn how to use Altair compose programm to see the result . Is there another way?
Welcome!
Welcome!
