JmySVMLearner C parameter question
Dear all,
I'm trying to use JmySVMLearner, but i have question that i'm not able to answer by myself.
One of the parameters of this operator is C, what happens if i select a C value= 0.0 ?does the algorithm switch to the linear separable case of the SVM (no constraint for the Langrange Multipliers) ?
Tank You in advance for your help
