🎉Community Raffle - Win $25
Join and Win
JmySVMLearner C parameter question
User: "niccolo_camarli"
New Altair Community Member
Updated by Jocelyn
Dear all,
I'm trying to use JmySVMLearner, but i have question that i'm not able to answer by myself.
One of the parameters of this operator is C, what happens  if i select a C value= 0.0 ?does the algorithm  switch to the linear separable case of the SVM (no constraint for the Langrange Multipliers) ?
Tank You in advance for your help
1 - 3 of 31
    User: "fischer"
    Hi,
    see the mySVM documentation:
    C: the SVM complexity constant. If not set, 1/avg(K(x,x)) is used.
    Here, 0 means "not set" :-)
    If you set the log level in the process root operator low enough, the SVM will log the value that is actually used.
    Cheers,
    Simon
    OP
    Thank you very much!!
    But  where  this 1/avg(K(x,x)) comes from?
    I found this value also on the website of Stefan Rüping (Mysvm ) and also on SVMlight website, could you give me some reference that explains  the reason of this C guess?
    Tank You
    User: "fischer"
    Hi,
    have a look at the references below. Thinking about it, it occurs to me that the formula I copied from the mySVM documentation may be wrong. Please have a look at the literature to be sure.
    Cheers,
    Simon
    http://www-stat.stanford.edu/~tibs/ElemStatLearn/
    Hastie, T., Rosset, S., Tibshirani, R. and Zhu, J. (2004). The entire regularization
    path for the support vector machine, Journal of Machine
    Learning Research 5: 1391-1415.
