"Bigram Document Vector"
D_M
D_M New Altair Community Member
edited November 2024 in Community Q&A
Hi,
I want to create document vector consisting only of bigrams.
For this I am first saving the wordlist using the following operators:-
TextInput
  StringTokenizer
and then I am using
TextInput
    StringTokenizer
    TermNgramGenerator
    StopWordFilterFile (using the previously saved wordlist.)
Is there any better way of doing this?
Welcome!
Answers
  • D_M
  • land
    land New Altair Community Member
    Hi,
    I guess it is. Why don't you just use it this way:
    TextInput
        StringTokenizer
        TermNgramGenerator
    The resulting vector will only contain the bi-grams, since it builds the vector from the tokens generated by all inner operators. If no token of a complete word is contained, it will not be part of the vector.
    Or did I misunderstand you completely?
    Greetings,
      Sebastian
  • D_M
    Thanks Sebastian for replying.
    I tried using only
    TextInput
      StringTokenizer
      TermNGramGenerator
    The problem I am facing is that along with the bigrams, unigrams are also coming to the document vector. I want only bigrams not unigrams. So to prevent this I have to use the StopWordFilter to remove the unigrams.
    Plez let me know if I can achieve this in a much better way?
  • haddock
    haddock New Altair Community Member
    What Ho D.M !
    Not really understanding much about anything I looked up on Wikipedia to understand what a bigram was, and found the following...
    An n-gram is a subsequence of n items from a given sequence. The items in question can be phonemes, syllables, letters, words or base pairs according to the application.
    Here http://en.wikipedia.org/wiki/N-gram
    What is the context of your application?
  • D_M
    Sorry, if my question is not clear.
    For me the bigram should composed of sequence of words.
    e.g. For - "the dog smelled like a skunk"  bigrams should be xx_the, the_dog, dog_smelled, smelled_like, like_a, a_shrunk, shrunk_xx.
  • land
    Hi,
    with RapidMiner 5.0 the result should exactly look like what you are expecting it to be. Otherwise there's no possibility to change this, but you could filter the not desired results using the example filter.
    You might specify a regular expression for filtering the attribute according to their names.
    Greetings,
      Sebastian
  • D_M
    thanks Sebastian for replying.
Welcome!
Welcome!
