Hi,
as I work with a text collection containing many, many words it contains also words like "label" and "id" already used for attribute names in an example set. I am getting warnings like the one below from the TextInput and I wonder whether there is an easy way to prefix all attribute names originating from words (similar to a StringToWordVector option -P known from Weka).
[Warning] TextInput: The original example example set already contains an attribute named "label".
This is likely to cause trouble. Please rename the attribute in the original example set.
Right now I don't believe it causes much trouble, but maybe I just missed some option in WVT TextInput to fix it.
Thank you very much!
/kirke
