Hi,
I'm tring to run RM on Ubuntu Jaunty 9.04(64 bit) with Kde 4.3.2.
Whenever I launch rapid miner, both with script(RapidMinerGUI) and java(java -jar ...), the execution stops immediately.
The window of rapid miner doesn't crash and remains open with the string "Creating Frame".
Only after 30-40 minutes rapid miner finally opens.
An example execution is below:
Starting RapidMiner from '/home/rp/Documents/rapidminer-4.6', using classes from '/home/rp/Documents/rapidminer-4.6/lib/rapidminer.jar'...
G Dec 19, 2009 2:38:20 PM: rapidminer.home is '/home/rp/Documents/rapidminer-4.6'.
G Dec 19, 2009 2:38:20 PM: ----------------------------------------------------
G Dec 19, 2009 2:38:20 PM: Initialization Settings
G Dec 19, 2009 2:38:20 PM: Default system encoding for IO: UTF-8
G Dec 19, 2009 2:38:20 PM: Load core operators...
G Dec 19, 2009 2:38:20 PM: Load Weka operators: true
G Dec 19, 2009 2:38:20 PM: Load JDBC drivers from lib directory: true
G Dec 19, 2009 2:38:20 PM: Load JDBC drivers from classpath: false
G Dec 19, 2009 2:38:20 PM: Load plugins: true
G Dec 19, 2009 2:38:20 PM: Load plugins from '/home/rp/Documents/rapidminer-4.6/lib/plugins'
G Dec 19, 2009 2:38:20 PM: Read rcfile '/home/rp/Documents/rapidminer-4.6/etc/rapidminerrc'.
G Dec 19, 2009 2:38:20 PM: Trying rcfile '/home/rp/Documents/rapidminer-4.6/etc/rapidminerrc.Linux'...skipped
G Dec 19, 2009 2:38:20 PM: Trying rcfile '/home/rp/.rapidminer/4_6_0_rapidminerrc'...skipped
G Dec 19, 2009 2:38:20 PM: Read rcfile '/home/rp/.rapidminer/4_6_0_rapidminerrc.Linux'.
G Dec 19, 2009 2:38:20 PM: Trying rcfile '/home/rp/Documents/rapidminer-4.6/scripts/rapidminerrc'...skipped
G Dec 19, 2009 2:38:20 PM: Trying rcfile '/home/rp/Documents/rapidminer-4.6/scripts/rapidminerrc.Linux'...skipped
G Dec 19, 2009 2:38:20 PM: Trying rapidminer.rcfile. Property not specified...skipped
G Dec 19, 2009 2:38:21 PM: Loading operators from 'operators.xml'.
G Dec 19, 2009 2:38:29 PM: Loading JDBC driver information from 'etc:jdbc_properties.xml'.
G Dec 19, 2009 2:38:29 PM: Loading renderers from 'ioobjects.xml'.
When execution stops for 30-40 minutes.
I already adjusted the JAVA_HOME and RAPIDMINER_HOME and I installed java6 (sun-java6) correctly.
Furthermore, the same thing happens with all rapid miner version: 4.2-4.6 and also with beta version.
Any help on this would be appreciated,
Thanks,
Mino.
