🎉Community Raffle - Win $25
Join and Win
"Read current process memory usage using the API"
User: "bjoern"
New Altair Community Member
Updated by Jocelyn
Hallo everyone!
I am new to RM and I am currently developing a little tool which sequentially starts different RM processes with the goal to track memory usage of each job.
Therefore I make use of the RapidMiner API in my own Java application and the processes run fine so far.  :)
Furthermore I created an additional thread which should periodically ask RM how much memory is currently in use and logs it to a file.
In fact, I need a possibility to access the memory usage information which the RM GUI shows in the bottom right. Is there a possibility to do that?
Thank you!
Björn
1 - 1 of 11
    User: "bjoern"
    OP
    I was thinking about this problem for hours... and right after I posted this topic, it came to my mind!  :D
    You can access the memory informations using following commands:
    Runtime.getRuntime().totalMemory() = current used memory
    Runtime.getRuntime().maxMemory() = total memory available to the VM
    Runtime.getRuntime().freeMemory() = free memory
    Maybe these information will help others.  ;)
    Björn
