Hallo everyone!
I am new to RM and I am currently developing a little tool which sequentially starts different RM processes with the goal to track memory usage of each job.
Therefore I make use of the RapidMiner API in my own Java application and the processes run fine so far.
Furthermore I created an additional thread which should periodically ask RM how much memory is currently in use and logs it to a file.
In fact, I need a possibility to access the memory usage information which the RM GUI shows in the bottom right. Is there a possibility to do that?
Thank you!
Björn
