Decision Tree
sudheendra
sudheendra New Altair Community Member
edited November 2024 in Community Q&A
Hai,
I have an unstructured Text document.I want to represent the related words as a Decision Tree, ie  If I use ChangeAttributeRole and input a particular word as label can I obtain a Decision Tree on the basis of this document?
Thanks,
Sekhar
Welcome!
Answers
  • haddock
    haddock New Altair Community Member
    Hi there,
    I'm having difficulty understanding this, could you give us some form of example?
  • sudheendra
    Hai,
    I am attaching some of my contents.
    Suppose it contains "He suffered head trauma and is still experiencing vision problems as a result of this accident" which is  repeating many  times in my Text  Data. So I need to get the relation between "accident", "vision" and "headtrauma" or in other sense if my decision variable is "vision" then the tree should contain "accident" and other related attributes.
    Thanks,
    Sekhar
  • haddock
    So the root node of the decision tree would be what?
  • sudheendra
    Hai,
    I have only one document. I am extracting ideas from the document.I dont know whether it is possible to take the entire document as root.In the above example is it possible to take "accident "as root? For the first time I am applying Decison Tree in Text document.So your help will be highly useful  :)
    Thanks,
    Sekhar
  • land
    land New Altair Community Member
    Hi,
    I doubt, that decision trees will be of great help for your problem. I don't see there any classification problem. Please remember, a classification problem is about assigning a class label, for example "red" or "green". What should be this label in your case?
    Greetings,
      Sebastian
  • sudheendra
    Hi Sebastain,
    I have a 50 text files. I need to classify the total documents into ''Good' and "Bad" on the basis of words ( ie If the documents contain loss,injury,damage etc then I need to classify it into "Bad", if the documet contain issued,payment,closed etc then I need to classify it into "Good")
    How can I proceed further?
    Thanks,
    Sekhar
Welcome!
Welcome!
