1 - 7 of
71
Hi there,
I'm having difficulty understanding this, could you give us some form of example?Hai,
I am attaching some of my contents.
Suppose it contains "He suffered head trauma and is still experiencing vision problems as a result of this accident" which is repeating many times in my Text Data. So I need to get the relation between "accident", "vision" and "headtrauma" or in other sense if my decision variable is "vision" then the tree should contain "accident" and other related attributes.
Thanks,
Sekhar
Thanks,
Sekhar
Hai,
I have only one document. I am extracting ideas from the document.I dont know whether it is possible to take the entire document as root.In the above example is it possible to take "accident "as root? For the first time I am applying Decison Tree in Text document.So your help will be highly useful
Thanks,
Sekhar
Thanks,
Sekhar
Hi Sebastain,
I have a 50 text files. I need to classify the total documents into ''Good' and "Bad" on the basis of words ( ie If the documents contain loss,injury,damage etc then I need to classify it into "Bad", if the documet contain issued,payment,closed etc then I need to classify it into "Good")
How can I proceed further?
Thanks,
Sekhar
Thanks,
Sekhar
