1 - 2 of
21
The short answer is that what you are trying to do, should work.
If a summary is not available to select in the Summary dropdown list, it is usually an indication that the fields are not available in the underlying table. I also tried what you are showing above and at first it appeared that it did not work. Once I selected a different table to apply a summary to and then go back to the table I wanted, the dropdown list updated and I was able to select the modified summary.
Thanks Chris, I'll review the fields and try it again!
