🎉Community Raffle - Win $25
Join and Win
Extract BLOB-Data with DatabaseExampleSource
User: "VD"
New Altair Community Member
Updated by Jocelyn
Hello,
I want to extract data from an Oracle-Database. It's possible to connect to the database and read all tables. However, for one data-type (BLOB = binary large objects) the table contains only '?'. What I would like to have is to see the data of the field MODUL_DATA as hex-string which I then can convert later ...
<operator name="Root" class="Process" expanded="yes">
    <operator name="DatabaseExampleSource (2)" class="DatabaseExampleSource">
        <parameter key="database_system" value="Oracle"/>
        <parameter key="database_url" value="jdbc:oracle:thin:@nu0xxxxxxxxxxxxxxxx"/&gt;
        <parameter key="username" value="XXXX"/>
        <parameter key="password" value="XXXX"/>
        <parameter key="query" value="SELECT &quot;ID_MM&quot;, &quot;MODUL_DATA&quot; FROM &quot;MES_AUMM&quot;"/>
    </operator>
</operator>
What should I do?
Thanks for your help
Best Regards
VD
