where is the probleme
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
SUBCASE       1
  LABEL PRETENSION
ANALYSIS NLSTAT
  SPC =        1
  NLPARM =        6
  PRETENSION =        4
  DISPLACEMENT(H3D) = ALL
  GPFORCE(,,) = ALL
  GPSTRESS(H3D,ALL) = ALL
  SPCFORCE(ALL) = ALL
  STRAIN = ALL
  STRESS = ALL
$HMNAME LOADSTEP               2'PRESSURE'       9
SUBCASE       2
  LABEL PRESSURE
ANALYSIS NLSTAT
CNTNLSUB YES
  SPC =        1
  LOAD =        3
  NLPARM =        6
  STATSUB(PRETENS) =       1
  GPFORCE(,,) = ALL
  STRAIN(H3D,ALL) = ALL
$HMNAME LOADSTEP               3'VERSCHIEBUNG'       9
SUBCASE       3
  LABEL VERSCHIEBUNG
ANALYSIS NLSTAT
CNTNLSUB YES
  SPC =        9
  NLPARM =        6
  GPFORCE = ALL
  SPCFORCE = ALL
  STRAIN = ALL
  STRESS = ALL
$HMNAME LOADSTEP               4'D_Verschiebung'       9
i want my model first  apply eine pretension, then eine pressure ,
in the third subcase, i applied a translation in modell
But the caculation untill subcase 2 ist right, the results of the 3 Subcase would be calculated, but on information depend on the first 2 Step.
Anyone have idee?
1 - 7 of 71
    Altair Employee
    OP
    Hi FalcoW
    can you try the below:
    1) Create a PRETENSION SUB CASE (image 1)
    2) Create a NLSTAT with pressure as LOAD and refer the PRETENSION subcase in STATSUB(PRETENS)
    3) Create the translation subcase and use CNTNLSUB with the 2nd subcase which is the pressure subcase.
    <?xml version="1.0" encoding="UTF-8"?>post-7616-0-35546500-1428390186_thumb.jp
    <?xml version="1.0" encoding="UTF-8"?>post-7616-0-43191100-1428390192_thumb.jp
    Altair Employee
    OP
    thxs for your answer.
    SUBCASE       4
      LABEL D_Verschiebung
    ANALYSIS NLSTAT
    CNTNLSUB 2
      SPC =       10
      NLPARM =        6
      DISPLACEMENT(,H3D,,,,,) = ALL
      GPFORCE(,,) = ALL
      GPSTRESS(,) = ALL
      STRAIN(,H3D,,ALL,) = ALL
      STRESS(,H3D,,,,,,) = ALL
    this my loadstep4, aber the results donot depend on my subcase 2(pressure load)
    Altair Employee
    OP
    for subcase 3 und 4 i have defided the translation als spcadd, ist ok? or must i this translation als load define?
    Altair Employee
    OP
    SPCADD will combine the SPCs. Are you trying to apply an enforced displacement to translate the nodes?
    Altair Employee
    OP
    yes
    Altair Employee
    OP
    Can you share the model?
    Altair Employee
    OP
    Hi,
    can you check for stress in your last sub case?
