🎉Community Raffle - Win $25
Join and Win
"Split Text"
User: "fmueller"
New Altair Community Member
Updated by Jocelyn
Hi guys
I have several Text files with difffrent number of words and i want to split it into Text Files with max 500 words?
How can i segment this Text Files in RapidMiner? I try it with the operator SplitSegmenter but i have no idea how i can set the regular expression.
Can anybode help me?
Regards
Florian
1 - 3 of 31
    User: "Ryujakk"
    Hi,
    I'm not really sure what you want...
    BUT! You can always try this regex:
    ([^\s]+\s){500}
    What it does is search for any number of non whitespace characters, followed by a whitespace character, this pattern repeated 500 times. It works on the site http://www.regexplanet.com/simple/index.html at least (credits to Sebastian for the URL  ;) ) !
    - R
    User: "fmueller"
    OP
    Thanks for your answer...
    So i will clarify my problem a little bit...for example:
    Text1.txt (Total: 110 words)
    Text2.txt (Total: 410 words)
    Text3.txt (Tota: 50 words)
    I need Text Files in 50 words blocks...the result should be:
    Text1.txt -> 3 Segments Files: Text1_Seg1.txt (50 words), Text1_Seg2.txt (50 words), Text1_Seg3.txt (10 words) = Total 110 words
    can i do this with the operator SplitSegmenter or TextSegmenter (TextMining PlugIn)
    Thanks for your answers
    User: "land"
    Hi,
    did you try the regular expression above? I don't know why it shouldn't work...
    Greetings,
      Sebastian
