🎉Community Raffle - Win $25
Join and Win
"How to get/set the vector of a text?"
gfyangUser: "gfyang"
New Altair Community Member
Updated by Jocelyn
Hi,
I want to get the vector (e.g., tf-idf) of a text , refine this vector, and then replace the original vector with the refined one. Is it ok by RM?
TextInput is able to provide a file containing the frequency information. Of course, we could calculate the tf-idf based on this file by ourselves, and get a new vector of tf-idf. Then, how to replace the original vector with this new vector?
Sincerely yours
gfyang
1 - 3 of 31
    OP
    I think I have solved it.
    A text vector is just an example in the ExampleSet, and changing the values in an example will change the corresponding text vector.
    landUser: "land"
    Hi,
    the text input operators will store the text vectors in an exampleset as example. So after they finished everything is just a normal example and you might do whatever you want to to on it...
    Greetings,
      Sebastian
    OP
    Thanks a lot :)
