🎉Community Raffle - Win $25
Join and Win
How to replace string in TextObject
User: "skarab"
New Altair Community Member
Updated by Jocelyn
Hi All,
Could somebody provide me information how to replace a fragment of TextObject? I can find TextCleaner but I do not know if there is one for replacing string?
Regards
skarab
1 - 2 of 21
    User: "skarab"
    OP
    See http://rapid-i.com/rapidforum/index.php/topic,1226.0.html
    My brute force solution:
    * You need to use TextObject2ExampleSet to get ExampleSet. After that work on attribute, which contains text.
    * finaly you use ValueIterator and SingleTextObjectInput to get back a TextObject
    Regards,
    skarab
    User: "land"
    Hi,
    unfortunately not in RapidMiner 4.x. Originally the TextObject was only made for simpler API access on RapidMiner, so many functions where missing, which are just a line away in Java. With RapidMiner 5 and the upcoming TextProcessing Plugin there the TextObject, now named Document, is the central object during text processing and hence there is an operator for replacement.
    Greetings,
      Sebastian
