"Multi-class Classification using SVM"
Hi,
I want to classify data into positive, negative & neutral.
For this I want to use 2 SVM one trained on positive & not positive data & the other on negative & not negative data. Now I want to take the data predicted as positive by the 1st classifier & not negative by the second classifier as positive & data predicted as negative by the 2nd classifier & not positive by the 1st classifier as negative. In rest of the cases I want to tag the data as neutral.
Is it possible to do this in Rapid-Miner in GUI Mode?
