🎉Community Raffle - Win $25
Join and Win
"Using SOM clustering o/p to re-create original table with cluster-id column"
ruserUser: "ruser"
New Altair Community Member
Updated by Jocelyn
I have performed the SOM based Clustering using the following operators:
- DatabaseExampleSource
- SOMDimensionalityReduction
- ChangeAttributeRole
The i/p table format is here:
id attr1  attr2 ....... attr50
0 val1  val2..................
1 val3  val4..................
I get the output like this:
id SOM_0
0    2
1    0
I would like to create a Table in the Database to include the cluster column with the original table. The new table should look like this:
id attr1  attr2 ....... attr50    SOM_0
0 val1  val2..................        2
1 val3  val4..................        0
How do I achieve it using the Rapidminer operators?
1 - 2 of 21
    ruserUser: "ruser"
    OP
    Great! I found the answer myself :-)
    I used the DatabaseExampleSetWriter to write the o/p of the SOM clustering into a new DB Table. Then, I can perform the Table 'join' operation to combine the original table with this new table. In the end, I have the desired result with the original table re-created with the Cluster-id column.
    I like working with the Rapidminer.
    Hi,
    You can do the same using RapidMiner by using the [tt]ExampleSetJoin[/tt] operator. You might also need to use the [tt]IOMultiplier[/tt] to create a copy of the original example set before you apply the clustering algorithm.
    Thanks, that's great.
    Kind regards,
    Tobias
