🎉Community Raffle - Win $25
Join and Win
No KE value in output block /TH/PART
User: "gopal_rathore"
Altair Community Member
Updated by gopal_rathore
Hi,
For getting individual KE, IE etc. I have gone for using output block and defined variable named DEF for the components with PART as card image. On seeing the results, I can see only internal energy and total energy in the plots and all other variables are giving value as zero. I am not able to understand this thing. The components are initially under motion and then there is an impact taking place. Thus KE goes up then should go down for the parts but I see zero values for KE . However the global values is showing correct values.
Kindly let me know for the same.
1 - 6 of 61
