Need help on removing classifier model skew
Hi,
To provide a bried background to my exercise,
My objective is to create a SVM Classifier model which would classify customer feedback(attribute) into one of the various categories(Label).For this am trying to generate features from feedback verbatims which I then pass as attributes to the model.
The issue that am facing is, it could be observed from the classification errors of the model that the model is highly skewed towards the categories where the number of occurences was high(for highest frequency segment: class precision = low but class recall = high), i.e, the categories with lower frequencies were also being predicted as the ones with highest frequency. I have tried weighting the lower frequency segments suitably to remove differences in the occurences, but the errors are only getting magnified. Please let me know if there is any other way in which this can be controlled.
Many thanks in advance,
Ram
Ram
1 - 11 of
111
Hi Keith,
I tried using Metacost operator in my modeling flow today, however I got error saying that it cannot take in numerical attributes, and I seem to be unable to understand if I should use it during the before or after %xvalidation operator in the flow. Could you please provide some link where I can find information on the same.
Thanks,
Ram
Thanks,
Ram
This works:
But this doesn't: Error in: MetaCost (MetaCost) This learning scheme does not have sufficient capabilities for the given data set: numerical attributes not supported
<operator name="SimpleValidation (2)" class="SimpleValidation" breakpoints="after" expanded="yes">
<parameter key="local_random_seed" value="10"/>
<operator name="JMySVMLearner" class="JMySVMLearner">
<parameter key="keep_example_set" value="true"/>
<parameter key="max_iterations" value="100"/>
<parameter key="calculate_weights" value="true"/>
<parameter key="return_optimization_performance" value="true"/>
<parameter key="estimate_performance" value="true"/>
<parameter key="balance_cost" value="true"/>
</operator>
<operator name="ApplierChain (3)" class="OperatorChain" expanded="yes">
<operator name="Applier (3)" class="ModelApplier">
<parameter key="keep_model" value="true"/>
<list key="application_parameters">
</list>
<parameter key="create_view" value="true"/>
</operator>
<operator name="BinominalClassificationPerformance (2)" class="BinominalClassificationPerformance">
<parameter key="main_criterion" value="AUC"/>
<parameter key="AUC" value="true"/>
<parameter key="lift" value="true"/>
<parameter key="false_positive" value="true"/>
<parameter key="false_negative" value="true"/>
<parameter key="true_positive" value="true"/>
<parameter key="true_negative" value="true"/>
</operator>
</operator>
Thank you for your help. I have a small positive rate, < 10%, and a small data set. So, I'd like to modify the cost for the learner and use cross-validation rather than oversampling (so I don't have to split into train, test, validate).
<operator name="MetaCost" class="MetaCost" expanded="yes">
<parameter key="cost_matrix" value="[0.0 1.0;5.0 0.0]"/>
</operator>
</list>
</operator>
</operator>
</operator>
</operator>
</operator>
Hi,
although you just sent a small part of the process, I can definitively say that this will not work. The MetaCost operator will need an inner learner for operating, hence it is called Metacost. It works simply like that:
For performing a cross-validation you need an inner learner. You want to modify the svm for the imbalanced class set by using the metaCost operator. Then put the SVM directly into the MetaCost operator and then put the MetaCost operator as learner inside the SVM.
Greetings,
Sebastian
Greetings,
Sebastian
This confuses me:
I tried that and it works. So, I think I am using it correctly. I'm getting the balancing I'm after.
Did you mean this:put the SVM directly into the MetaCost operator and then put the MetaCost operator as learner inside the XValidation
Thanks for your help!!
<operator name="confidence estimate" class="XValidation" breakpoints="after" expanded="yes">
<parameter key="create_complete_model" value="true"/>
<operator name="MetaCost (2)" class="MetaCost" expanded="yes">
<parameter key="cost_matrix" value="[0.0 3.0;1.0 0.0]"/>
<operator name="KernelNaiveBayes (5)" class="KernelNaiveBayes">
<parameter key="estimation_mode" value="full"/>
<parameter key="number_of_kernels" value="35"/>
</operator>
</operator>
<operator name="OperatorChain (2)" class="OperatorChain" expanded="yes">
<operator name="ModelApplier (2)" class="ModelApplier">
</list>
</operator>
<operator name="Performance (2)" class="Performance">
</operator>
</operator>
You might also look at the MetaCost operator to increase the penalty for misclassifying the rarer instances.
Hope that helps. I'm sure other people smarter than me will chime in as well. :-)
Keith
