Altair RISE
Nominate Yourself Now!
create index attribute
User: "keyser84"
New Altair Community Member
Updated by Jocelyn
I want to create an attribute which contains the index (0,1,2,3,etc.) of the instances (in the same order as in the arff file).
How do I do this in RapidMiner GUI?
1 - 3 of 31
    User: "steffen"
    Hello,
    Use the operator "IDTagging". Note that if you already have an attribute with role "id", it is going to replaced. To avoid this, change the role of id-attribute temporarily using the operator "ChangeAttributeRole".
    hope this was helpful
    regards,
    Steffen
    User: "keyser84"
    OP
    Thank you... I just wanted to plot id/index on x-Axis and some values on y-Axis.
    I used ChangeAttributeRole operator to make it regular (otherwise it cannot be plotted).
    User: "haddock"
    Hi there,
    If you are as lazy as I am, you can use the series plotter, then you don't even need an Id column, and you can plot the labels etc..
    Just my indolent two cents...
