🎉Community Raffle - Win $25
Join and Win
"Neural Networks Performance"
User: "mksaad"
New Altair Community Member
Updated by Jocelyn
Hello,
I am trying to measure Neural Networks Performance as training cycles increase. I need to plot cycles vs performance.The problem is the performance values is the same in all training cycles !!!!!  ???  :-\ . are there some thing wrong with my code?
<operator name="Root" class="Process" expanded="yes">
    <operator name="ArffExampleSource" class="ArffExampleSource" breakpoints="after">
        <parameter key="data_file" value="D:\Users\Motaz\Documents\rm_workspace\sample\weka-data\cpu.arff"/>
        <parameter key="label_attribute" value="class"/>
    </operator>
    <operator name="ParameterIteration" class="ParameterIteration" expanded="yes">
        <list key="parameters">
          <parameter key="NeuralNet.training_cycles" value="50,75,100,150,200,300,400,500,600,700,800,900,1000"/>
        </list>
        <operator name="NeuralNet" class="NeuralNet">
            <parameter key="keep_example_set" value="true"/>
            <list key="hidden_layer_types">
              <parameter key="sigmoid" value="5"/>
            </list>
            <parameter key="learning_rate" value="0.3"/>
        </operator>
        <operator name="ModelApplier" class="ModelApplier">
            <parameter key="keep_model" value="true"/>
            <list key="application_parameters">
            </list>
        </operator>
        <operator name="RegressionPerformance" class="RegressionPerformance">
            <parameter key="relative_error" value="true"/>
        </operator>
        <operator name="ProcessLog" class="ProcessLog">
            <list key="log">
              <parameter key="cycles" value="operator.NeuralNet.parameter.training_cycles"/>
              <parameter key="performance" value="operator.RegressionPerformance.parameter.relative_error"/>
            </list>
        </operator>
    </operator>
</operator>
Thanks,
Motaz
1 - 1 of 11
    User: "haddock"
    Hi there Motaz,
    I think the error is here
    All should be fine when you change to value instead.
    Good weekend
