<operator name="Root" class="Process" expanded="yes"> <operator name="ExampleSetGenerator" class="ExampleSetGenerator"> <parameter key="target_function" value="random"/> </operator> <operator name="IOMultiplier" class="IOMultiplier"> <parameter key="io_object" value="ExampleSet"/> </operator> <operator name="IdTagging" class="IdTagging"> <parameter key="create_nominal_ids" value="true"/> </operator> <operator name="SOMDimensionalityReduction" class="SOMDimensionalityReduction"> </operator></operator>
dubito ergo sum ("I doubt, therefore I exist") and si fallor sum ("If I am deceived, I exist")
I stress the phrase "semblance of reason", because no matter what you do you will be left with doubt, known here as the "Curse of MIerswa" - did you realise that "Ingo Mierswa" can be rearranged as "imagine rows"?
Ingo Mierswa wrote:By the way: thanks again for your valuable posts which I enjoy not only reading because of their quality in terms of the topic but also because of the quality of language. You really should consider to write a true "Data Mining Novelette". I would certainly buy it!
