🎉Community Raffle - Win $25
Join and Win
"How to speciffy Group-By-Attributes with the Aggregation Operator"
User: "Legacy User"
New Altair Community Member
Updated by Jocelyn
Hi,
unfortunately I'm not able to count an attribute by a group. What I want to do is:
1. I load a model
2. Apply the data set (discrete label)
3.  try to count for each group of the label the model outcome
I always get an error that my specified group_by_attributes (= flower_type) does not exist.
(flower_type is the label)
Do I have to change the Role of the attribute via ChangeAttributeRole? I tried it already but I does not work
Here the correspondng xml-file:
    <operator name="Teststichprobe" class="ExcelExampleSource">
        <parameter key="decimal_point_character" value=","/>
        <parameter key="excel_file" value="\\Swbfs002\Informationssysteme\Berichtswesen\Aufgaben\Schulungen\RapidMiner\Beispiele\iris_teststichprobe.xls"/>
        <parameter key="first_row_as_names" value="true"/>
        <parameter key="id_column" value="6"/>
        <parameter key="label_column" value="5"/>
    </operator>
    <operator name="ModelLoader" class="ModelLoader">
        <parameter key="model_file" value="\\Swbfs002\Informationssysteme\Berichtswesen\Aufgaben\Schulungen\RapidMiner\Beispiele\model_dt_iris.mod"/>
    </operator>
    <operator name="ModelApplier" class="ModelApplier">
        <list key="application_parameters">
          <parameter key="sum(flower_types)" value="flower types"/>
        </list>
    </operator>
    <operator name="Aggregation" class="Aggregation">
        <list key="aggregation_attributes">
          <parameter key="prediction(flower_type)" value="count"/>
        </list>
        <parameter key="group_by_attributes" value="flower_type"/>
    </operator>
</operator>
Cheers
Thomas
1 - 2 of 21
    User: "Legacy User"
    OP
    Hi Guys,
    I fixed it  wih an appropriate Performance-Operator (Anyway, I would like to know how to solve my explained problem above.
    Cheers
    Thomas
    User: "IngoRM"
    Hi Thomas,
    probably the "flower_type" attribute was still set to a special role (label) and was hence not found by the aggregation. Here is an example:
    <operator name="Root" class="Process" expanded="yes">
        <operator name="ExampleSource" class="ExampleSource">
            <parameter key="attributes" value="C:\Dokumente und Einstellungen\Mierswa\Eigene Dateien\rm_workspace\sample\data\iris.aml"/>
        </operator>
        <operator name="NaiveBayes" class="NaiveBayes">
            <parameter key="keep_example_set" value="true"/>
        </operator>
            </list>
        </operator>
        <operator name="ChangeAttributeRole" class="ChangeAttributeRole">
            <parameter key="name" value="label"/>
        </operator>
        <operator name="ChangeAttributeRole (2)" class="ChangeAttributeRole" activated="no">
            <parameter key="name" value="prediction(label)"/>
        </operator>
              <parameter key="prediction(label)" value="count"/>
            </list>
            <parameter key="group_by_attributes" value="label"/>
        </operator>
    </operator>
    Cheers,
    Ingo
