"Market Basket Data Format"
1 - 8 of
81
Hai,
Thanks for the Information, I tried what you explained here, but i still in error. could you suggest to improve it.
ERROR:- TID does not exists.
Thanks
Priyan
Thanks
Priyan
<operator name="Root" class="Process" expanded="yes">
<operator name="CSVExampleSource" class="CSVExampleSource">
<parameter key="filename" value="C:\rapid.csv"/>
</operator>
<operator name="Nominal2Binominal" class="Nominal2Binominal">
</operator>
<operator name="ChangeAttributeRole" class="ChangeAttributeRole">
<parameter key="name" value="ITEM"/>
</operator>
<operator name="Aggregation" class="Aggregation">
<list key="aggregation_attributes">
<parameter key="TID" value="sum"/>
</list>
</operator>
<operator name="Example2AttributePivoting" class="Example2AttributePivoting">
<parameter key="group_attribute" value="TID"/>
<parameter key="index_attribute" value="ITEM"/>
</operator>
<operator name="ResultWriter" class="ResultWriter">
<parameter key="result_file" value="C:\result16.res"/>
</operator>
</operator>
Hi,
probably it's exactly what it states: TID doesn't exist. Please use a breakpoint before and check if this attribute still exists. But I assume, that it has been binomalised and hence doesn't exist anymore. You have to ensure that only ITEM is binomalised. Thatfore you have to change the role of TID into Id and ensure that ITEM is binominal.
Greetings,
Sebastian
Greetings,
Sebastian
Hai,
Thanks for the Info. I changed according to your feedback though still i am in problem.
for Example2AttributePivoting :- Group Attribute & Index Attribute.
What can i do with these two attributes.
Priyan
Thanks
<parameter key="filename" value="C:\Documents and Settings\Administrator\Desktop\excel\rapid.csv"/>
</operator>
</operator>
<parameter key="name" value="TID"/>
<parameter key="target_role" value="id"/>
</operator>
</list>
</operator>
<parameter key="group_attribute" value="ITEM"/>
<parameter key="index_attribute" value="TID"/>
</operator>
<parameter key="result_file" value="C:\Documents and Settings\Administrator\Desktop\answer16.res"/>
</operator>
</operator>
Priyan
Hai,
I am really sorry to ask again here, i got stuck with this. sorry for troubling you.
the code i used
Do i need to add more than this to format the data.
i get finally this result only( image 2)
It would be a great help if you could give a feedback sir.
thanks
priyan
[attachment deleted by admin]
the code i used
What i can use for the Group by attribute on the image i attached in the Aggregation. (image 1)
</operator>
</operator>
</operator>
</list>
</operator>
</operator>
</operator>
thanks
priyan
Hi,
starting from your original post (and using the data you provided there) this is the process which performs the desired transformation from transactional data to the basket data format:
Please note that you have to adapt the input operator.
Cheers,
Ingo
<operator name="SimpleExampleSource" class="SimpleExampleSource">
<parameter key="filename" value="C:\Dokumente und Einstellungen\Mierswa\Desktop\market_data.txt"/>
<parameter key="read_attribute_names" value="true"/>
</operator>
<operator name="IdTagging" class="IdTagging">
</operator>
<parameter key="name" value="id"/>
</operator>
</operator>
<operator name="Numerical2Polynominal" class="Numerical2Polynominal">
</operator>
<operator name="AttributeSubsetPreprocessing" class="AttributeSubsetPreprocessing" expanded="yes">
<parameter key="condition_class" value="attribute_name_filter"/>
<parameter key="attribute_name_regex" value="TID"/>
<parameter key="invert_selection" value="true"/>
<operator name="Mapping" class="Mapping">
<parameter key="attributes" value=".*"/>
<list key="value_mappings">
</list>
<parameter key="replace_what" value="?"/>
<parameter key="replace_by" value="false"/>
<parameter key="add_default_mapping" value="true"/>
<parameter key="default_value" value="true"/>
</operator>
</operator>
<operator name="FPGrowth" class="FPGrowth">
</operator>
</operator>
</operator>
</operator>
</operator>
</operator>
</operator>
</list>
</operator>
</operator>
</operator>
</operator>
Cheers,
Ingo
this is indeed possible. You should at first binarize your Item attribute using the nominal2binominal operator. You then will get a column for every possible value of item, each Line exactly containing one 1 for an item.
You then could aggregrate over the tid using the aggregation operator, building the sum over examples having the same tid. So there is finally only one row for every transaction, containing the values of sold items in the appropriate attributes.
Greetings,
Sebastian
